I gave 2 problems. When the truck sits for several days, there is not enough power in the battery to start it.. I have had to buy a gizmo to shut the battery off when I am not using it, All the driving that I do is short lived, so the battery doesn't get to much time to recharge. In a way, although I wish I didn't have to use it, it is kind of a security feature, in that if someone hot wired it, they could not start it, because the battery is turned off.
The second problem which I have had since I bought it several years ago, is whenever I put the SUV, in reverse, the drivers side mirror goes out of kilter, so I have to adjust it.
Other that the 2 problems that i have had , I really have no major problems with the Hummer H2.
I do thank you for your input on these 2 problems.
Any input you can give me would be greatly appreciated.
Jun 2, 2013 at 10:48 AM
