Bogging down when press gas pedal and little battery power
JCARRICK
  • 2004 FORD ESCAPE
  • V6
  • 4WD
  • 256,800 MILES
I had a bad battery I replaced it and car bogs down when I press accelerator what could it be? Never a problem until replaced bad battery.
Tuesday, October 1st, 2019 AT 11:35 PM
  • 52,797 POSTS
Good morning,
Little battery power? Please explain?
Does the battery drain overnight?
https://www.2carpros.com/articles/car-battery-dead-overnight
As far as the engine, it could be from a low voltage as you need to resolve the battery issue first.
https://www.2carpros.com/articles/engine-has-low-power-output
Wednesday, October 2nd, 2019 AT 3:48 AM
BMDOUBLE
  • 1,139 POSTS
Also check the air filter housing for any obstructions on the filter side. Some people like to remove the air filter housing while replacing the battery and either forget to plug in the mass airflow sensor or they don't latch the housing together correctly and bugs/debris enter the mass airflow sensor and cause chaos. Just another thought.
Wednesday, October 2nd, 2019 AT 8:46 AM
