2005 Hyundai Tuscon
SABITINO
  • 2005 HYUNDAI TUCSON
  • 6 CYL
  • FWD
  • 72,000 MILES
Shakes between 60-70 mph subsides going around corners on freeway air pressure good tires are normal ware
Saturday, June 19th, 2010 AT 6:21 PM
MERLIN2021
  • 17,250 POSTS
If it happens only at high speed and no brakes applied, check tire balance, if OK, check for bent rims, or shifted belt on tires, Jack the front up, start car, put in drive, watch front wheels, bent rims and shifted belts on tires are easy to spot this way, tires will appear uneven(wobble). If they are OK, they will appear straight(no wobble).
Saturday, June 19th, 2010 AT 6:41 PM
