2003 Hyundai Tiburon Car Problems
20CLARK10
  • 2003 HYUNDAI TIBURON
2003 Hyundai Tiburon 4 cyl Front Wheel Drive Automatic
I am having problems with my car. Water keeps mixing with the oil what is causing this problem. I had to replace my old radiator and installed the new one. The car cut off on me the other day. Come to find out it ran hot again but the meter stick didn't show that it wasn't getting hot, the car just turned off.
Tuesday, June 8th, 2010 AT 1:30 PM
  • 109,867 POSTS
If you have coolant mixing with the motor oil, you have a bad head gasket or warped head if it was overheated.
Check that and let me know what you find. You will most likely need to run a compression test on it to find out.
Monday, June 21st, 2010 AT 10:27 PM
