Hello -
Well, what I need you to do is please go to Auto Zone (AZ) or O'Reilly's (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
Get back with me once you have pulled the codes so we can take it from there. Also, I just want to make sure you have checked the fluid level and it is sitting correct?
SPONSORED LINKS
Sunday, December 7th, 2008 AT 12:17 AM
