Feels like the car is not shifting properly
145,000 MILES • 2.7L • 6 CYL • TURBO • AUTOMATIC
LOCKE273
I scanned my car with a OBD2 sensor i bought at a local Walmart. i am no car guy so i am figuring it out as i go but hit a roadblock. When i am driving my car it is not shifting properly and does not want to go over forty mph. The Error codes i got on my O2 scanner where for the camshaft sensor and the throttle position sensor. I replaced the throttle position sensor and still have the issue. It idles higher than normal as well even after it warms up. If there is anything else i need to provide to help find some answer just ask and I will go get it. i am just trying to get my baby running smooth again.
Much thanks to those who take the time to read.
May 21, 2017 at 6:43 AM
  • 55,770 POSTS
If the catalytic converter is partially plugged it will cause the problem you are describing. Here is a guide to help you test if this could be the problem.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
May 24, 2017 at 6:17 AM
