2000 Hyundai Tiburon 2000 Hyundai Tiburon will not start
WARRENW66
  • 2000 HYUNDAI TIBURON
  • 4 CYL
  • FWD
  • MANUAL
  • 176,000 MILES
I went out of town for about 6 weeks and my Hyundai Tiburon sat without being started and when I returned and tried to start it, it would not do anything. It was completely dead. I tried jump starting it and the only thing I had then was the door ajar light and still nothing happened. I went ahead and replaced the battery and then I got the door ajar light and the key-in-the-ignition chime, but still no other accessory lights, clock, or anything else electrical. I have had the car since it was new without any problems until this. I know cars can be finicky after sitting so long, but I don't see why it would just die completely.
Thank You
Thursday, May 28th, 2009 AT 9:30 PM
  • 109,867 POSTS
Make sure the ground wire to the engine block is clean and tight.
Tuesday, June 2nd, 2009 AT 1:11 PM
WARRENW66
Thank You for the reply. I actually found the problem. I found that the 100 amp fusible link had blown somehow. I replaced it and the car started right up. Not sure how it blew just sitting, but it was a relatively easy fix.
Tuesday, June 2nd, 2009 AT 2:59 PM
  • 109,867 POSTS
Glad you got it going. Corrosion can play tricks on wiring, so maybe sitting gave it the chance to finally go bad. Let us know if you have trouble in the future.
Wednesday, June 3rd, 2009 AT 5:46 PM
