Replacing my accessory drive belt(s)
2004 HYUNDAI SONATA
IHATEMYSONATA
Noises problem 4 cyl Front Wheel Drive Automatic 57000 miles
Almost exactly a year ago I had to take my car in to the dealership because my hydroaulic tensioner went out and I believe they changed the belt too. Thank goodness it was covered by the warranty I still had on it. They replaced it and it was working fine then I just took it in the other day because my door locks weren't working and they fount that I have a cracked accessory drive belt!
I don't know if this is a timing belt or THE drive belt or what but I can't afford to pay out the butt for a stupid belt on my stupid car!
Thankfully I have a very nice dad and boyfriend that are somewhat mechanically inclined that could probably do this for me but I need to find a diagram so they can do this without any mistakes.
I have checked the owner's manual and it doesn't show how the remove the parts for replacement.
Can anyone help me with this???
PLEASE!!!!!!
Jan 2, 2009 at 8:28 AM
  • 55,423 POSTS
Here is are a couple guides to help you see whats going on when doing the job.
https://www.2carpros.com/articles/replace-serpentine-belt
This is what is like for your car
https://www.2carpros.com/diagrams/hyundai/sonata/2004
The serpentine belt is what drives the alternator power steering pump etc. Its probably what they meant because you cant see the timing belt unless covers are removed.
There is a pulley tensioner assembly that acts as a tensioner for the serpentine belt. You can find it by looking for a pulley that doesn't drive a pump, is on a short bracket with a spring that applies tension toward the belt and is not the pulley on the crankshaft. It pivots to loosen the belt when pressure is applied to the center bolt through the pulley.
Draw a diagram of how the belt turns around all the pulley BEFORE you remove the belt and look for a sticker on the underside of the hood or on the radiator support for a drawing of the belt route.
Use extreme caution, when tension is on the wrench, turning the belt tensioner assembly , that the wrench doesn't slip catching a finger between the belt and pulley.
Use a long wrench or a combination of wrenches for leverage to apply pressure to the tensioner pulley assembly bolt, in the direction that releases the tension off the belt, until the belt is loose, about a 1/4 turn. hold tension while slipping the belt off one of the pulleys then release the pressure off the wrench, letting the tension off of the pulley tensioner assembly.
Assemble in reverse, wrapping belt around all pulleys except the tensioner pulley, or most convenient pulley, until tensioner is sprung back enough to accept belt.
This is a very simple repair but must be done safely and correctly to make sure all belt ribs of the belt are in the grooves of the pulleys correctly.
It may take someone 45 min to 1 hour the first time, but the second time probably only 15 min. It sounds a lot more complicated than it really is.
Cheers, Ken
Oct 12, 2017 at 11:17 AM
