2004 Hyundai Sonata alternator
JOSEPHR
  • 2004 HYUNDAI SONATA
2004 Hyundai Sonata 4 cyl Front Wheel Drive Automatic 140k miles
Hi
I already donated I want to know about the same alternator, when removing the CV axle, how you do it?
Do you take the wheel off then the bottom screw of the ball joint, then the Axel screw then you pop the axle with a screw driver? And that thats about it for the axel? I want to know if its the right procedure? To take the axel out, only a screw driver to pop it out?
and put it back in to click? Let me know thanks
Thursday, March 25th, 2010 AT 6:38 PM
MMPRINCE4000
  • 8,548 POSTS
Remove wheel and ball joint and tie rod (outer). Remove axle nut and pull knuckle out so axle will clear knuckle.
Axle pops out, use large screwdriver. Axle pops in, you may have to use long screwdrive on tripod to get it in.
Friday, March 26th, 2010 AT 7:23 AM
