2003 Hyundai Sonata aircon pump not kicking in
2003 HYUNDAI SONATA
68,750 MILES • 4 CYL • 2WD • AUTOMATIC
JOHAN 1
I recently had the aircon pump replaced, but only went to fill up the gas today.
The technician who was responsible for filling up, said they could not as the pump was not kicking in when you switch on the aircon. Should it not first be filled with gas before the aircon will start working, or can the pump start working without any gas, as there is no pressure to kickstart the pump.
Oct 8, 2010 at 1:46 AM
KHLOW2008
  • 41,814 POSTS
Hi Johan 1,
The AC compressor would only kick in if there is sufficient pressure in the system and static pressure is required.
Get a new person to do the job, the guy you went to does not know about A/C system and is not going to do a good job for you.
Oct 8, 2010 at 4:01 AM
