2005 Hyundai Sonata fuel pump relay
2005 HYUNDAI SONATA
68,000 MILES • 4 CYL • FWD • MANUAL
GRAYWOLF50
my car will start an run an idle about 3 to 4 seconds an then it will die like it is starving for gas or it is flooding i replaced the fuel pump an now i am at a loss at what to check now
May 18, 2010 at 2:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
starving for gas and flooding are two opposite problems so the first thing to do would be figure out which it is. if it is starving for fuel then the fuel filter could be clogged or the fuel injectors may be dirty. if it's flooding then the fuel injectors may be stuck open or the spark plugs not getting healthy spark.
May 18, 2010 at 2:56 PM
