After I installed the Alt, it was squeaking a little bit so I tightened the adjust bolts accordingly. After there was no squeak, everything seemed to be fine, but about 10 minutes into driving the battery light came on! Then I was driving and the headlights blew? Also the air bag light flashed a little bit as well as the hazards. Both VERY random. The fog lights still work as well as the interior cluster panel lights, but no headlights.
Is it possible the alternator is in fact faulty and blew the headlights? Or bad ground? Or some sort of relay?
SPONSORED LINKS
Sunday, December 6th, 2009 AT 2:06 PM
