2000 Hyundai Sonata not running
YELLOWGIRL
  • 2000 HYUNDAI SONATA
  • 4 CYL
  • FWD
  • 152,852 MILES
My car shut off why I was driving
Monday, July 26th, 2010 AT 1:31 PM
Could be a compression, fuel or spark problem do below to determine why
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, July 26th, 2010 AT 3:11 PM
