1997 Hyundai Sonata cutting out
AJDYER
  • 1997 HYUNDAI SONATA
Engine Mechanical problem
1997 Hyundai Sonata Manual 93000 miles
Hi there,
Our car has done this twice now.
All of a sudden when we are driving along it will shiudder then lose all its power.
We have to pull over to the kerbside.
It has also failed to start promptly on two occasions (are the incidents connected
What could be the problem.
We want to use the motorway in June for our hols,
but not with a car that cuts out.
I look forward to your reply
updated 6/9/09
Hi there, you replied to ask me if the light was coming on, on the dashboard.
No it is not coming on.
The car is tootling along, then it just judders and seems to go into neutral (it is an automatic)
We have to pull over and switch off, then restart after a while.
Do you think it could be the gear box.
Thank you
Sunday, May 31st, 2009 AT 7:53 AM
  • 109,740 POSTS
HAs the check engine light come on? Have you checked fuel pump pressure? Also, is there any noise coming from your catylatic converter?
Friday, June 5th, 2009 AT 11:51 PM
  • 109,740 POSTS
When it seems to go into neutral, does the engine rev smoothly?
Tuesday, June 9th, 2009 AT 2:23 PM
AJDYER
Thank you kindly.
Yes the car does run smoothly.
But we do not get anywhere, there is no power at all.
You are very kind with your help.
From Angela.
Wednesday, June 10th, 2009 AT 4:42 AM
  • 109,740 POSTS
If the engine revs smoothly but the car doesn't move in gear, it does seem to be a problem with the transmission. The only thing that confuses me is the idea that it was hard to start a few times. That tends to make me think it is a problem with another item. However, at this point, I would recommend having it looked at by a transmission tech for his / her opinion. If the trans fluid is full and the car doesn't move, it could be a sensor, torque converter, front pump.
I wish I could be more specific, but this is one that will need to be checked one thing at a time.
Let me know what you find.
Wednesday, June 10th, 2009 AT 12:24 PM
