I recommend rotating tires, front to back, or even balancing them, and see if there is any change. Although tires may be good, balance can be an issue. You have done a very good job listing specific symptoms, and some are not an exact match for a tire balance issue, but it's important to remove tires as a possible source.
SPONSORED LINKS
Monday, May 4th, 2009 AT 6:43 PM
