Steering problem
2002 Hyundai Santa Fe 4 cyl Two Wheel Drive Automatic 116k miles
I replaced a power steering pump on this 2002 santa Fe approx. 15k miles ago. the same problem seems to be happening again. When I replaced the initial pump the splines designed into the pulley and the pump drive shaft had worn smooth. Why is that and what should I do to fix it?
Jun 21, 2009 at 1:41 PM
