Spark Plug
HYUNDAI
MDODONOGHUE
I have a Huynday Elantral model year 2000.
112,000 miles
4 cyllinder engine
While changing the spark plugs I realized that one of the rubber boots stayed on one of the plugs. Therefore I am unable to get the spark plug socket onto the plug to loosen it and remove. These plugs are recessed about 8 inches inside a metal tube. I removed the valve cover hoping the tube could be removed. Unfortunately there is no clear way to remove the tube and now I am hopeing you can help. :mrgreen: :mrgreen:
Aug 18, 2007 at 9:45 AM
2CARPRO JACK
  • 11,533 POSTS
Take a coat hanger or other thin metal and make a small hook on one end. Stick it between the plug and boot and turn so the hook grabs the rubber boot and pull it out. Might still take a little patience, that is usually how they come out
Aug 19, 2007 at 12:42 AM
