Power Window won't go down
HYUNDAI
MOMOF1
2000 Hyundai Elantra, 135,000 miles
The driver's power window doesn't want to go down. If you knock on the panel it'll go down a little bit. It goes up just fine. Is this a problem with the motor or regulator or what? All the other windows are working fine.
May 20, 2007 at 8:55 AM
TURBOTUFF20G
  • 98 POSTS
more than likely its the switch itself,,but it could also be something hanging up on window tracks or regulator , does it bind up or is there any abnormal noises when it does go up?? if not then its probably the switch,, if you know how to use a trst light or multimeter you could check to see if you get switching 12volts at motor
May 27, 2007 at 12:16 PM
