Overheating
HYUNDAI
SABALDWIN0069
I have a 1996 Hyundai Accent GT 16 valve five-speed manual transmission with 153K miles. The car over heats when traveling faster than 65 MPH. I don't see a lot of movement when I open the radiator cap, when hot and no foam, and I don't hear any noises from water pump. The car stays cool traveling a low speeds (all day long), but I removed the thermostat and have noticed a slight improvement at high speeds. It should be noted that the car has been extremely hot a couple of times and I must top-off anti-freeze (about a pint) every two days (I travel 200 miles per day). Spark Plugs have shown a slight green tinge at tip, but overall the car runs great (especially in cool weather). Both radiator fans work and there is no leak anywhere I can see. I once put in some fiberglass stop-leak, maybe too-much?
Jun 11, 2007 at 9:20 AM
MIKE H R
  • 3,094 POSTS
cars work better with a themastat. it keep the fluid from circulating to fast and not letting the cars radiator work properly. use a low temp themastat. back flush the system with the themastat out. the radiator could have a clog in it. with loosing anti freeze you could have the system pressure checked to see where you are loosing antifreeze.
Jun 11, 2007 at 10:26 AM
