1995 Hyundai Excel Overheating Fans
That's the problem, I can't seem to find the sensor.
Suggested Repair
Inspect the cooling-fan and A/C auxiliary-fan relays in the fuse/relay box. Debris between the relay contacts can stop the fans from switching on even when fuses and wiring look good. Clean the contacts and remove debris from the box, then confirm both fans operate.
Conversation Summary
A 1995 Hyundai Excel Twin-Cam was overheating because the radiator and A/C auxiliary fans would not switch on. Fuses and visible wiring were intact, and the owner could not locate a separate thermo switch. An expert suggested tracing the coolant sensor and related wiring near the throttle body and coolant lines. The owner later found ants throughout the fuse/relay box; three relays were affected, with ants between contacts on two of them. Cleaning the relay contacts restored fan operation.
