1997 Hyundai Accent O2 Sensor Location
HYUNDAI
JDUGUID
Hey! This is in regards to my 1997 Hyundai Accent Sport (194,000 km / 1.6L SOHC, 5-speed manual transmission). I have my own pocket OBD II code reader, and I'm getting a check engine light for an O2 sensor (P0133: "O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)"). Thing is, my car has TWO oxygen sensors. How can I figure out which one this memory address (Bank 1, Sensor 1) refers to physically on the car?
The code book I have has the following available locations listed for O2 sensor issues:
Bank 1 Sensor 1
Bank 1 Sensor 2
Bank 1 Sensor 3
Bank 2 Sensor 1
Bank 2 Sensor 2
Bank 2 Sensor 3
From what the book includes about O2 sensors, they're usually malfunctioning when they're responding slowly. Is there any way to check this response with a meter or some other way? Do you know what this location translates to on my car?
Thanks in advance!
- James
Apr 26, 2007 at 1:47 AM
BRUCE HUNT
  • 3,754 POSTS
Bank 1 and Bank 2 refer to the National Bank of Chicago and Philly. Kidding. They refer to the two side of a v engine. Since your engine is a straight inline 4 cylinder you only have bank 1. There is usually two O2 sensors upper and lower (pre-cat and post-cat) The post actually acts as a monitor for the cat. Pre is Sensor 1 and post is sensor 2.
May 1, 2007 at 12:42 AM
Suggested Repair
On this inline-four, Bank 1 Sensor 1 is the upstream (pre-catalytic converter) oxygen sensor. Sensor 2 is the downstream sensor that monitors the catalyst. Diagnose or replace the pre-cat sensor for the slow-response code.
Conversation Summary
The owner of a 1997 Hyundai Accent with code P0133 asked which physical oxygen sensor Bank 1 Sensor 1 identifies. The expert explained that an inline engine has only Bank 1, Sensor 1 is the pre-cat sensor, and Sensor 2 is the post-cat sensor.
