2000 Hyundai Elantra, 87K MI, Engine 2.0 4 cylinder in-line DOHC engine.
10 weeks after having the trans fluid changed at a drive through shop the transmission went out. The dealership tells me that Scrub a Dub uses a trans fluid that requires a modifier to make it compatible but it isn't compatible. Therefore, the warranty is void.
An independent shop says that the band drum failed/the splines stripped. (My words/interruption)
If this is true, how can Scrub a Dub sell the trans fluid? Did I really do this to my car? Does the lack of fluid cause this problem? How is the warranty from Hyundai?
Feb 2, 2007 at 2:07 PM
