Transmission fluid and filter change help
HYUNDAI
ZEEBART
I have a 97 hyundai Tiburon, and I need to change the transmission fluid and filter...is this difficult to do and can anyone tell me how and where to start :?:
Nov 8, 2007 at 2:47 AM
BRUCE HUNT
  • 3,754 POSTS
Generally there are two methods. One is the draining from the pan on the tranny. It basically replaces the fluid in the tranny but there is usually still fluid in the lines to the radiator and radiator. The new will mix with the old. Then there is a flush where all fluid is pushed out of the system and it is generally cleaned. More expensive and should be performed at a garage with the proper equipment to complete the flush. The first you could do yourself.
Nov 8, 2007 at 8:52 AM
