Heating system
HYUNDAI
WILDTHING
  • 9 POSTS
I have a 99 sonata,230 kms. The blower motor works at all speeds but there is no air flow out any of the ducts either on heat or a/c. All the fuses are ok.
Could it be the cabin air filter or should i start taking apart the dash to diagnose.
Nov 28, 2007 at 6:18 AM
FISHERMAN
  • 937 POSTS
[quote:1d2ac3c581="wildthing"]I have a 99 sonata,230 kms. The blower motor works at all speeds but there is no air flow out any of the ducts either on heat or a/c. All the fuses are ok.
Could it be the cabin air filter or should i start taking apart the dash to diagnose.[/quote:1d2ac3c581]
Hello !!
start checking the cabin filter if good then check the duct vents and diverters for proper operation.. could be a "stuck" diverter.
Good Luck!
Nov 28, 2007 at 7:04 AM
