i have a 2002 hyundai sonata 84000k/m 2.4L could you let me know
where is the fuel filter located
Mar 7, 2007 at 11:19 AM
Access the fuel filter under the rear seat. Remove the bottom cushion and fuel tank sender cover, remove the gas cap to relieve pressure, then disconnect the ground wire and fuel lines from the filter.
The owner of a 2002 Hyundai Sonata 2.4L asked where the fuel filter is located. The expert said it is reached under the rear seat by removing the bottom cushion and sender cover, relieving pressure at the gas cap, and disconnecting the ground wire and fuel lines.
