2000 Hyundai Accent Noisy Engine
HYUNDAI
AENSSLE
i have a 2000 Hyundai accent (2nd owner, so no warranty)
1.5l engine 4 door automatic 84,000 miles
Car is in the shop and they tell me i have a broken crankshaft!
Car runs still, but makes a hell of a racket.
can a car still run with a broken crankshaft???
could it be a material defect?
would it make sense to replace just crankshaft or would i be better off buy a used engine?
May 3, 2007 at 3:03 AM
BRUCE HUNT
  • 3,754 POSTS
The mileage is low and I would go for a defect in the crank. I sounds more like a piston problem than a crank. The piston arm could be loose on the crank causing the racket. I would wonder about getting a short block which is the engine without the head and thus new rings and bearings. See how that compares to a used engine. The rebuilding of yours is a possibility however, it is also possible that damage has been caused to the block as well. Did you ever have the engine oil drop really low?
May 3, 2007 at 5:46 AM
AENSSLE
once, the oil warning light came on, on a really curvy windy road. replenish oil in less then 5 miles.
*headscratch* i just can't imagine an engine would run with a broken cranc, so i think your guess is more likely, cause i had that happened before!
Low oil and lost a sleeve on a rod but that sounded a lot worse then this one now!
It was back in the 80' on a ford escort.
If i lost a sleeve on a rod, would you think it did further damage to the block?
thx for the quick reply!!!
May 3, 2007 at 6:10 AM
BRUCE HUNT
  • 3,754 POSTS
I do know that the sound would be loud with the slap of the piston cap being loose or worn. I have seen a vehicle with a crack crankshaft that ran for another couple of thousand miles but the break was at such an angle that allowed it to contine to rotate. However, the noise that engine gave was not loud. And knowing that the metal on the piston is probably aluminum versus the crankshaft which is steel it is likely that no damage could have been done to the crank. I would sure want an honest mechanic to do the work and only put in what is needed. Same principle does not apply to the block as that is probably aluminum alloy.
May 3, 2007 at 6:59 AM
Suggested Repair
Have a trusted mechanic confirm whether the noise is a loose connecting rod or piston rather than a broken crankshaft. Compare a short block with a used engine, and rebuild only if the block is undamaged. Prior low oil may have contributed.
Conversation Summary
The owner of a 2000 Hyundai Accent with 84,000 miles was told the crankshaft was broken, though the car still ran and made a loud noise. The expert said the noise sounded more like a loose connecting rod or piston and noted that a cracked crank can sometimes still rotate. After the owner reported a brief low-oil warning, the expert advised an honest inspection, replacing only what is needed, and comparing a short block with a used engine because the block may also be damaged.
