2000 hyundai 2.4 crankshaft position sensor
2000 HYUNDAI
ADAY1970
I am just curious as in what it take to replace the cps in a 2000 hyundai with a 2.4... do you have to remove the front cover and the motor mount or can it be done with out doing that... Thanks Alan
Apr 24, 2007 at 4:50 AM
TURBOTUFF20G
  • 98 POSTS
there is alot involved,, u need to remove timing belt covers,, motor mount, then u need to remove t-belt. The wire then is routed up the front left side of the block behind power steering pump and tensioner bracket, these also need to be removed,, it gets alittle involved
May 28, 2007 at 7:58 AM
ZOMBIE1243
  • 6 POSTS
Thanks I did it, didnt remove the timing belt tho, just unpinned the connector and fed it under the belt..Thanks for the input
May 29, 2007 at 6:28 AM
