Hyundai Elantra Fuel tank
GATECRASHER
  • HYUNDAI ELANTRA
Other Category problem
Hyundai Elantra Engine Size unknown Front Wheel Drive Manual 120k miles
Hi, the problem I am having is regarding fuel backup in the tank. As I am fueling up my car, I can fill.3 gallons of gas and it backs up, causing the pump to stop fueling. Not sure what is causing this problem, any suggestions?
Sunday, December 23rd, 2007 AT 4:15 PM
BLACKOP555
  • 10,371 POSTS
First try different angles of the nozzle when filling and check to see the fuel filler hose isnt kinked.
If those are good you may have a restricted or shut check valve on the top on the fuel tank, also you may have a plugged, cracked, vaccum line going to it.
If those two are good then you have a bad carbon canister.
Monday, December 24th, 2007 AT 8:50 AM
