2008 Hyundai Elantra cranks over but does not start on firs
PRISPALOMO
  • 2008 HYUNDAI ELANTRA
Engine Mechanical problem
2008 Hyundai Elantra 4 cyl Two Wheel Drive 38800 miles
I put gas one evening and the next morning when going to start the car it did not start on the first crank. I cranked it again and it started right up. If the car sits for more than about 20 or 30 mins. It will not start on first crank. If you turn it off and try starting again within a couple of minutes of turning the car off, it starts right up on first crank. What can cause this? The only thing I did was put gas before this started. Before that no problems. The car runs fine. No hesitation or stalling. The check engine light hasn't came on at all either.
Tuesday, October 27th, 2009 AT 7:41 AM
Could be one of the following coolant temperature sensor, fuel pump relay, ignition switch -Check the fuel pressure
Tuesday, October 27th, 2009 AT 9:10 AM
PRISPALOMO
Thank you very much. Now when I take it in, I won't be so clueless as to what it might be and maybe the dealership will not try to take advantage of me as a woman, as some do out there. I appreciate it.
Tuesday, October 27th, 2009 AT 9:45 AM
SALNICKY402
  • 4 CYL
  • FWD
  • 76,000 MILES
So I was driving down the interstate going sixty mph with cruise control on. All of the sudden my car acted as if it shut of. I put the car in N and tried to start to vehicle as I was driving down the interstate and it would crank but it would not start. Plenty of gas in the car. Any ideas would be very helpful. Thank you.
Monday, August 14th, 2017 AT 6:13 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Here is a guide that will help us start looking for what is wrong.
Cheers, Ken
Monday, August 14th, 2017 AT 6:14 PM
