2001 Hyundai Elantra car lacks power
2001 HYUNDAI ELANTRA
175,000 MILES • 4 CYL • FWD • AUTOMATIC
BYLLH74
  • 26 POSTS
Hi, I was given an 01 hyundai elantra that didnt run. didnt know what happened to it but i did get it running. i put a new head gasket in it, all the valves were ok and no warpage. i also replaced the main and rod bearings cause of knocking. when i started i placed everything at top dead center along with the camshafts. it starts and runs, but it lacks power. i keep getting the code 0340 (cam position sensor) which i have replaced. any ideas where to go next?
Jun 30, 2010 at 2:16 AM
  • 31,937 POSTS
Hi there, start with re checking the cam timing, it may be a tooth out, start here.
Mark (mhpautos)
Jun 30, 2010 at 3:11 AM
BYLLH74
  • 26 POSTS
Thank you. I will recheck all the timing marks today. Ill post my results after I finish
Jun 30, 2010 at 3:17 AM
  • 31,937 POSTS
OK, if the timing is correct, we will look further into this problem.
mark (mhpautos)
Jun 30, 2010 at 3:21 AM
BYLLH74
  • 26 POSTS
sorry, i have been sick and havent worked much on the car. I did check the timing and it was right on. i did set it ahead and behind a tooth. setting it 1 tooth back did make it run even worse. but forward didnt change it much at all. the history on the car i know is that it broke about a year ago. the owner said it just stopped and wouldnt do anything. prior to that it did have a new head and gasket put in. but nothing on the lower engine. it was supposedly ran out of oil cause of a stripped oil pan drain plug (which i replaced with another oil pan from wrecking yard). its sat in her driveway for about a year until i picked it up a few weeks ago. maybe gas is bad. im not sure where to go with it. it still gives me the code 0340 (cam position sensor). thanks, i appriciate your help on this project.
Jul 5, 2010 at 1:23 PM
  • 31,937 POSTS
I must apologise my self, i am on leave just now and i have just popped into an Internet cafe to check my Emails, i will be back on line full time next week, i don't have any information on hand to work with just now.
Mark
Jul 5, 2010 at 2:02 PM
BYLLH74
  • 26 POSTS
no problem Mark. thanks so much for getting back to me. enjoy
Bill
Jul 5, 2010 at 2:57 PM
  • 31,937 POSTS
Hi Bill,
I am back at home now, can you give me an up date as to where your at with this problem?
mark.
Jul 9, 2010 at 11:03 PM
BYLLH74
  • 26 POSTS
hey Mark, I hope you enjoyed your time away. As far as the car, I haven't done much with it since the timing. I did find out that the gas in the tank has been sitting for about a year or a little more. Don't know if that could cause it to have no power. It seems like it lacks power when I push on the gas. At idle it sounds really good. Still have the code 0340 (cam position sensor). Compression is right at 150 on all 4 cylinders. Transmission fluid is full and oil is good. If u need any more info, let me know. Thanks again
Bill
Jul 10, 2010 at 12:55 PM
  • 31,937 POSTS
HI Bill,
Had a great time, holidays are always way to short, but back to the salt mines we must head, lol..... OK, With the valve timing correct and a cam sensor indication still showing we may have a bad connection at the loom plug, maybe a corroded terminal or a loose pin, i would drain the stale fuel and flush the lines, replace the fuel filter and add a liberal dose of injector cleaner as well, go through these steps and get back to me with what you find, also don't disregard a faulty sensor if all checks are ok.
Mark (mhpautos)
Jul 10, 2010 at 2:29 PM
