2001 Hyundai Elantra
HROWE07
  • 2001 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 93,000 MILES
I have a 2001 hyundai elantra, and about 2 weeks ago, my battery and parking brake light came on. I asked a friend about it and they told me that I needed a new altenator, so he put a brand new altenator in for me. The battery connectors were also changed out cuz there was a lot of corrosion on them. About a week after, I was driving home from works and my radio keep dying and I was loosing lights, I made it home and shut off my car. The battery was dead, so I went out and bought a new battery. And about another week went by and my lights were getting dim on the clock and radio cut in and out. My check engine light came on, and when I got to my destination, I shut my car off and the battery is now dead again. I've had the ground bolt check and made sure it was tightened a few time, but this keeps seeming to happen. Is there something we're missing that we should check?
Tuesday, August 24th, 2010 AT 2:22 PM
  • 109,913 POSTS
I would first have the new alt rechecked to make sure it is charging. If it is, then there must be a bad fuseable link between the alt and battery or you have a serious electrical draw that is killing the battery.
Let me know what you find.
Wednesday, August 25th, 2010 AT 8:14 PM
HROWE07
I have had the altenator tested and we replaced it with another new altenator. Still no luck, the battery isen't even being charged. I check to continuity to make sure it was connected and we had continuity, but still the alternator is not charging the battery. The altenator is charging itself. I had a friend mention a voltage regulator? Is there one on my 2001 hyundai elantra or not? I'm at the end of what I could think it would be.
Sunday, August 29th, 2010 AT 4:51 PM
  • 109,913 POSTS
I want you to try this test:
https://www.2carpros.com/how_to/how_to_test_alternator.htm
Tell me what you find.
Monday, August 30th, 2010 AT 8:46 PM
HROWE07
My cousin stopped by and looked at it. It was the 100 amp fuse for the battery that was blown. Finally got it fixed. Thanks for all the help!
Monday, August 30th, 2010 AT 8:54 PM
  • 109,913 POSTS
That will do it. I'm glad it is fixed. Let us know if you have other questions in the future.
Wednesday, September 1st, 2010 AT 7:01 AM
