2000 Hyundai Elantra obd2 code P0750 Shift Solenoid A malfu
2000 HYUNDAI ELANTRA
NEEZERSMOM
Transmission problem
2000 Hyundai Elantra 4 cyl Front Wheel Drive Automatic 75.000 miles
Just bought this 2000 Hyundai Elantra GLS on Friday and on Saturday the check engine light came on. Went to Advance Auto Parts and they read the codes: P0750 and P0441. How do you replace the shift solenoid a and can my husband, who is a pretty good mechanic, do it himself? Is it safe to drive this car until it's fixed as I don't have any other vechicle and will need to use it until then. Also, how does he go about repairing the EVAP emission Contol System Purge Flow Fault?
Oct 17, 2010 at 7:42 AM
LEGITIMATE007
  • 5,121 POSTS
how long have you had this vehicle?
Oct 17, 2010 at 12:14 PM
NEEZERSMOM
I just bought the car 3 days ago. Bought it Friday and the light came on Saturday after I drove it only 40 miles. Don't know what kind of upkeep it had. Unfortunately, I bought it "as is", so I'm stuck making the repairs. I don't know if it's ok to drive it until it's fixed, since I drive 80 miles daily for work. I'm more worried about the shift solenoid a and if it will ruin the transmission if it's not fixed. There are only 75,500 miles on the car. I will try to replace the gas cap and see if that helps the P0441 code. Seems that's the easiest fix for now. If that doesn't work, maybe we'll have to replace to purge valve.
Oct 17, 2010 at 8:59 PM
LEGITIMATE007
  • 5,121 POSTS
was it purchased from a dealer though?. I am just so disturbed right now. because in the back of my mind , something is telling me they just turned the check engine lights off until they sold it, just becuase you bought it as is does not mean its ok to mislead the customer, that is too much of a coincidence.....no light when you bought it, twenty four hours later, the engine light comes on? granted these are not major fixes, however, you should not be responsible for it. so my question is, did you buy this from a dealer?
Oct 17, 2010 at 10:57 PM
NEEZERSMOM
No, I didn't buy it through a dealer. It was a used car lot. They have agreed to fix the P0441 problem, even though they didn't want to at first. When they put code reader on it, the only code that came up was the P0441, not the P0750. We do have a friend with a transmission shop who told us to let him know if the check engine light comes on again and let him know what the car was doing when it came on, ie: rough shifting, slipping, and he would be able to tell us more. Said it wasn't too big a deal, so I'm feeling better about that. Is it posisible that when my husband used the obd2 at the parts store, that P0750 code was for someone else's car, and it wasn't cleared before he used it? I don't know how they work, so don't know if that could happen.
Oct 19, 2010 at 11:05 AM
