2000 Hyundai Elantra Fans work intermitently
2000 HYUNDAI ELANTRA
13,000 MILES • 4 CYL • FWD • AUTOMATIC
DERRYDAD
My A/C coolant fan does not come on when I depress the a/c button and turn the blower on. Also my radiator fan does not come on forcing my car to overheat. However a gentle tap of each motor gets both fans spinning. I think they may work intermitenly. I was planning on replacing both motors. What do you think?
Jun 28, 2008 at 12:38 PM
KHLOW2008
  • 41,814 POSTS
Hi derrydad,
Don't replace them soon, you should replace them now.
The fan motor carbons have run out and it will create a lot of problems like overheating and non cooling AC.
If the compressor fails to cut off when the system heats up, it can cause high pressure in the system and burst some hoses or pressure relief valves.
Jun 28, 2008 at 11:21 PM
