Hi, First I'd Check The Computer For codes. If No codes, I'd Check The Fuel Pressure. If All the Above Is ok, Then Look At The Ignition System, Crank Sensor, If It Has One, Or Coil, And Pick up Coil, If It Has One. There Are a few Things That Can Cause this. As You Can see. Parts Can Be Costly. I Would not Replace Any parts Till I knew What Was Bad. It Needs to Be checked out By Your Mechanic.
Hope This Helps You,
Good Luck
Edward S.
SPONSORED LINKS
Sunday, July 25th, 2010 AT 8:48 AM
