Monday, March 31st, 2008 AT 10:27 AM
System not charging, new alternator (old one did test bad before replacing it), 100A fusible link in good order. Haynes & Chilton don't make a manual for this model year yet(so I'm told). I've read something about an "IG" wire from the alternator but not sure which of the two in the harness that would be and what exactly to look for. I did check continuity from alternator B+ to battery +, and engine ground to battery -, all looks good at less than 1 ohm. Any advice would be gratefully appreciated.
