Transmission problem
2001 Hyundai Accent Front Wheel Drive Automatic 54000 miles
management light comes on intermitentley slow to pull away and you have to use full throttle to get up banks
Friday, May 14th, 2010 AT 8:06 AM
MECHANIC
HI there,
There is a set fault code lodged in the ECU, you will need to get a scan done to read this code and this will give us an indication as to the actual fault with the car, start here.
