1997 Hyundai Accent check engine light
CHRISWOOD
  • 1997 HYUNDAI ACCENT
  • 4 CYL
  • 13,900 MILES
I degreased the motor then power washed it. The car ran really bad for awhile and the check engine light came on. It still runs rough help
Friday, March 28th, 2008 AT 11:42 PM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
Also go to an air station and blow dry the electrical connectors, you have water where you shouldn't.
Saturday, March 29th, 2008 AT 7:51 AM
