1995 Hyundai Accent Brakes are squeaking / lurching
56,000 MILES • 4 CYL • 2WD • AUTOMATIC
CYTOSOL
I obtained a 1995 Hyundai Accent Hatchback a year ago. It sat on my driveway for about 4 months, and when I started to drive it I noticed the brakes were rusted and made a horrible noise while braking.
I brought my car in to have all the brakes / rotors replaced. After about 2 or 3 months of driving it, I noticed that the front brakes are making squeaking and sometimes clunking noises, even when the brake pedal isn't depressed. When I do press my break, I feel a distinct lurching every time the wheel goes around, as well as my break pedal bobbing up and down as the wheels rotate.
I believe the rotor is likely warped, but I am more wondering what could have caused this to happen after 4 months of replacing the rotors? I don't want to spend another $600 to replace to brakes to have this happen again in a few months.
Thanks for your advice
Jan 28, 2010 at 2:50 AM
DOCFIXIT
  • 18,828 POSTS
Common cause is wheel lugs being over torqued. Had tires replaced or balanced since brakes?
Jan 28, 2010 at 4:00 AM
CYTOSOL
Thanks for your reply. The tires were replaced with winter tires about 3 months ago. This problem was happening before the tires were replaced, however.. But this is still something I will look at.
Jan 28, 2010 at 4:07 AM
