1999 Hyundai Accent how to adjust a brake pedal
113,000 MILES • 4 CYL • FWD • MANUAL
JESUSVARGAS
how to adjust a brake pedal ? cause my brake lights are not working bulbs are good all the other lights work but not the brake ligths. what could it be?
May 24, 2010 at 1:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse if OK check brake light switch
May 24, 2010 at 9:26 AM
JESUSVARGAS
fuses are good, bulbs are good too, brake switch is good. what is the problem now? :?
May 24, 2010 at 6:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if fuses, bulbs and brake light switch is good then culprit is multi function (turn signal) switch, brake light circuit runs through the turn signal switch also.
May 25, 2010 at 7:43 AM
JESUSVARGAS
yeah! about that my turn singnals work some times but when the turn singnals work the brake ligths dont so whats the problem? =)
May 25, 2010 at 9:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
switch is definitely bad and needs replaced
May 25, 2010 at 12:50 PM
