Chasing oil leak, in itself, is a chore, especially when it only leaks while you are driving. This is what I can suggest. On your way home from work, stop at your local parts store and grab a couple of cans of brake cleaner.
The next morning you are off work, open the hood. Locate all places where you can see oil residue. Spray the brake cleaner where you can see these oil gunks until everything is clean. Don't forget to put cardboard or old newspaper under the car to catch the stuff from hitting your driveway. The next time you drive the car, as the engine is free of oil, you can easily see where the leak is coming from. This will only work if you have external leak.
SPONSORED LINKS
Thursday, March 19th, 2009 AT 11:56 PM
