2007 Hummer H2 Changing out handles/buckets on H2
2007 HUMMER H2
41,000 MILES • V8 • AWD • AUTOMATIC
POPPEE59
I'm changing the handles/buckets for the h2 and the back two were fine. Got to the front and the windows are in the way of the screws for the handles.Prob have to move the windows but how?
Thanks- I'm not sure the proper amount to donate so don't be offended.
Apr 2, 2009 at 9:13 AM
FACTORYJACK
  • 4,159 POSTS
Yes, removing the glass is the preferred method. Lower the glass all the way and remove the outer sealing strip(runs along the outside window sill, pushed down on pinch weld). Raise the glass until you can see the clamp fasteners(I believe there are 2). Loosen just enough to lift the glass from the clamps. The glass will come out through the window opening frame, may have to be turned and tilted.
Apr 2, 2009 at 2:54 PM
