2005 Hummer H2 gear ratio
40,000 MILES • V8 • AWD • AUTOMATIC
RAYE
can i change my gear ratio in my h2 from 4.10 to 3.73 to achieve better gas milage.. can i put in lockers to disengage my all wheel drive to only 2 wheel drive
Oct 18, 2008 at 3:22 PM
DR LOOT
  • 2,311 POSTS
of course you can change it, as long as you change the front axle to, you can not have different gears in the front and in the rear. now I will tell you the consequences, that 2005 hummer is all computerized, including the speedometer, and the computer is going to think you're going slower in adjusting your fuel mixture, you'll have to take it to the dealer after you are done and have them reconfigure your computer to match the gear ratio, that is why the driver's door has a sticker indicating proper tire size, so you don't interrupt the computers sensors, for maximum fuel economy.
Feb 28, 2009 at 2:52 AM
