2005 Hummer H2 DOOR LOCKS
2005 HUMMER H2
43,000 MILES • V8 • 4WD • AUTOMATIC
ANSTEDA
We have remote entry locking system on our 2005 Hummer H2. All the doors open & lock fine, except for the rear hatch door. It will not lock. Not with either the remote control or manually. Is there something we can do to fix this?
Thank you for your advice.
Darlene & Darrin
darlene@wasagahomes.com
Mar 6, 2010 at 12:16 PM
FACTORYJACK
  • CAR REPAIR CONTRIBUTOR
  • 4,159 POSTS
It would at least require removing the liftgate trim panel, and checking that the linkage is connected. First, if you listen at the door, either internally or externally, do you hear any thumping when activated. This would at least indicate that a signal is getting to the lock actuator. If after determining there is no noise, and the linkage is connected, you would need to check if a signal is getting to the lock actuator. You can do this with a test light across the two terminals. It should light with either command, the circuit just reverses polarity. See if that gets you anywhere.
Mar 9, 2010 at 10:23 PM
