How to turn off daytime driving lights
80,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
DSTOTT1965
Turn off daytime driving lights?
Feb 9, 2019 at 12:26 PM
  • 110,251 POSTS
The DRL are not a programmable parameter for this vehicle. There is no way of turning them off other than eliminating power to the system. They do not have a separate fuse. If you have the HID system, you can remove the fog light relay to prevent them from coming on, but then you can't use the fog lights.
The DRL are controlled by what is called the Smart Junction Box (AKA GEM or Generic Electronic Module). I see no way of turning them off.
Feb 9, 2019 at 2:08 PM
DSTOTT1965
Thanks for the reply. Does the safety netural switch send the power for the driving lights or are there a switch in the shifter.
Feb 10, 2019 at 10:38 PM
  • 110,251 POSTS
Welcome back:
The power is supplied via the smart junction box (AKA the GEM/generic electronic module).
Feb 11, 2019 at 10:43 AM
