2003 Ford Mustang Left Turn Signals
LATINO09HEAT
  • 2003 FORD MUSTANG
  • 6 CYL
  • 82,000 MILES
My left turn signals are flashing faster than my right turn signals, how do I fix this? And my car is making sounds as if it were congested whenever I accelerate, how do I fix this?
Thursday, April 30th, 2009 AT 11:17 PM
RACEFAN966
  • 5,029 POSTS
Ok one problem at a time here. First the turn signals. Have you turned them on and make sure both front and rear bulbs are working?
On the sound it makes does it seem to be coming from the exhaust or under the hood? Get back to me with what you know and we will go from there. You may need a digital multi meter at one point for the turn signals depending on what might be wrong if the bulb is good ok. Has there been any performance mods done to you ride? Like on my Mustang V-6 I have done some performance mods. Get back to me I need all the info you can get me ok.
Friday, May 1st, 2009 AT 10:30 AM
LATINO09HEAT
Yes all my lights work, turn signals, headlights and breaklights. All the bulbs work and the noise from the car is coming from under the hood. As far as changes/mods to the car, I a about to install a cold air intake.
Saturday, May 16th, 2009 AT 2:49 AM
RACEFAN966
  • 5,029 POSTS
OK I need you to check fuse 13 and 18 both are 15 amp. Look closer to fuse 13. As for the cold air intake you will like it I got more hp and 3 miles more to the gal. Let me know what you find.
Monday, May 18th, 2009 AT 9:55 AM
