How to remove alternator from a 2003 Lincoln Navigator?
200,000 MILES • 5.4L • V8 • AUTOMATIC
ELIZA34
  • 8 POSTS
I want to see if my alternator needs to be replace, but I don't know how to remove it since theres a part on top of the alternator that needs to be remove first. Can you please help me and tell me how to remove it please.
Dec 25, 2015 at 7:22 AM
you can check your own alternator while it is on the car. get a voltmeter and check the voltage with the engine running. it should be 14 to 14.5 volts
the top piece has 4 attaching bolts. they are 8 mm bolt heads. remove them and the plate moves. release the serp belt and just loosen the 2 lower bolts and the alternator lifts up
Dec 25, 2015 at 8:00 AM
ELIZA34
  • 8 POSTS
Thank you very much.????
Dec 25, 2015 at 2:18 PM
ELIZA34
  • 8 POSTS
ELIZA34
  • 8 POSTS
WE TOOK THE ALTERNATOR TO OREILYS AND THEY CHECKED IT AND SAID THAT IT COMES OUT THAT IT WORKS. BUT THE ALTERNATOR HAS A SMALL NOISE AND HAS ALOT OF GREASE. THE ALTERNATOR IS THE ORIGINAL BRAND MOTORCRAFT AND MY TRUCK IS 2003 LINCOLN NAVIGATOR.WE TOOK THE BATTERY TO AUTOZONE AND THEY SAID IT IS WORKING. SO MY QUESTION IS WHAT COULD IT be. MY TRUCK STARTED TO TURN ON BATTERY NOT CHARGING IN RED THEN THE SPEEDOMETERS LIGHT STARTED TO TURN OF AND ON THEN WENT OFF COMPLETELY. THEN MY TRUCK WENT OFF DIDNT WANT TO TURN ON. THEN WE PUT CABLES ON THE TRUCK AND TURNED ON BUT IMMEDIATELY STARTED TO DO AGAIN WHAT I TOLD YOU AND TURNED OFF. SO PLEASE WHAT COULD IT BE. PLEASE HELP....
Dec 26, 2015 at 7:57 AM
it sounds like the alternator is failing. dim lights, flickering lights and the red battery light are indicators.
Dec 26, 2015 at 8:01 AM
ELIZA34
  • 8 POSTS
Thank you very much Roy. Tommorrow ill buy it.
Dec 26, 2015 at 12:19 PM
ok
Dec 26, 2015 at 12:25 PM
ELIZA34
  • 8 POSTS
I INSTALLED A NEW BATTERY AND NEW ALTERNATOR AND NOW MY TRUCK WORKS.
Dec 27, 2015 at 6:59 AM
ELIZA34
  • 8 POSTS
I HAVE A QUESTION. MY BROTHERS CAR HAS THE ETC LIGHT ON. ITS A MAGNUM 2007. HE ALREADY TOOK IT TO AN ELECTRICIAN AND THEY REPROGRAM IT. WELL ONE WEEK LATER THE LIGHT STARTED AGAIN. WHAT THE CAR DOES IS WHEN HE GETS TO A STOP SIGN AND TRIES TO GO . THE CAR DOESNT MOVE RIGHT AWAY IT TAKES SECONDS FOR THE CAR BE ABLE TO MOVE. PLEASE WHAT COULD IT BE??
Dec 29, 2015 at 2:58 AM
I would need to see the codes. have them check for codes
Dec 30, 2015 at 1:31 AM
ELIZA34
  • 8 POSTS
Thanks he said he cleaned the throttle and that the light is not on anymore.
Jan 1, 2016 at 2:21 AM
