how to remove a steering column tilt lever knob
90,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
MIKE VASSAR
Can you please tell me how to remove a steering column tilt lever knob?
Dec 10, 2016 at 1:28 AM
CARADIODOC
  • 34,415 POSTS
If it is the same as those from the late 1990's, it unscrews. Look for two flats, about a half inch long, about an inch from the steering column cover. If it is tight enough to require a wrench, that is the place to use it. You will need one smaller than 1/4". You can find wrenches that small in ignition wrench sets. You can also wrap a rag around the shaft, (about two or three layers), then grab it with a pliers.
Dec 10, 2016 at 3:05 AM
STEVE W.
  • 15,420 POSTS
2002 Ram has a small paddle that pulls off. if you pull it toward the steering wheel while twisting it. Then you remove the bottom steering column shroud and there is a bolt that holds the lever itself to the column.
Dec 10, 2016 at 11:25 AM
CARADIODOC
  • 34,415 POSTS
Thank you Steve W.
Dec 12, 2016 at 3:12 AM
