[quote:aad4abf4f0="tpoyadou"]92 Honda Prelude
F22B2 Accord engine installed as replacement engine
I just replaced my cam and crank seals and in the process of changing them bumped the car out of time. It cant be more than a few degrees either way but I am not sure which way it shifted.
I am trying to find some sort of walk through to place the car back in time so that I can get it back on the road.
I wasn't sure if I should place this in the Accord section becuase of the engine or the Prelude section becuase of the car.
Any help would be appreciated.[/quote:aad4abf4f0]
Put the no.1 piston on its compression stroke-line the crank pulley with the indicator at TDC- Remove the D/Cap is the distributor rotor pointing to the no.1 tower of the cap-if its a hair-loosen the distributor and turn it till the rotor is pointing exactly under the no.1 tower.
This don't make it, you have to redo the valve and ignition timing-meaning you have to open it up and line all markings at TDC and rotor pointing to no.1 tower.
Sep 7, 2007 at 8:24 AM
