1993 Honda Prelude Oil Leak
FLYGUY0808
Hi, I have a 1993 Honda prelude SI 2.2 L Manual car. it has ab 190,000 miles on it. The car use to run great, but for ab a week or so, it has started to smoke up. after driving it for awhile i smelled something burning, when i looked under the car i noticed the exuast pipe wuz burning oil on top of it. and also, by the spark plugs. so i know the car is leaking oil. It seems like a small leak because only a couple of drops will go on the ground, the rest burns off. Is this a gasket problem? or is it something else? and my friend said that if i pour this enigne cleaner with the oil it might be able to stop the leak. could that work? If anyone has any idea how to make this stop that will be great, thanx.
Oct 10, 2007 at 3:45 PM
FAIRRACING31
  • 150 POSTS
It sound's to me that you are going to have to replace your valve cover gasket. Engine cleaner will not fix any oil leaks.
Oct 10, 2007 at 6:27 PM
FLYGUY0808
ok thanx, but do u know around how much that would be. I know the part is around 30 dollars, but around how much is labor? And can i drive around with it for a lil while like that? cuz all its doing is smoking when some oil gets on the exaust, but yet theres no puddle of oil under the car when it stops.
Oct 11, 2007 at 5:52 AM
Suggested Repair
Replace the valve cover gasket. Engine cleaner added to the oil will not stop the leak.
Conversation Summary
The owner of a 1993 Honda Prelude SI with about 190,000 miles reported smoking and a burning smell after driving, with oil burning on the exhaust and near the spark plugs. Only a few drops reached the ground. They asked whether a gasket was leaking and whether engine cleaner in the oil could stop it. The expert said the valve cover gasket needs replacement and that engine cleaner will not fix an oil leak. The owner then asked about labor cost and whether short-term driving was safe, but no further expert reply was given.
