I've recently rebuilt the head of my 1994 honda prelude 2.3l engine. All gaskets and seals replaced. I continue to have a small leak coming from the driver side of the engine. My mechanic cannot get a visual on the leak. he says it could be the oil pump, or a crack in the block or somewhere else? I've researched a product called "heal a seal" where supposedly it seals cracks and warped valves. Is there something else you would recommend? I had a mechanic even recommend using tomato paste in the engine to seal up leaks??? Ever hear of that b4???
Jun 1, 2007 at 4:04 AM
